Want to add a kicker to a '05 90 - couple questions
  • Want to add a kicker to a '05 90 - couple questions
    I'd like to add a 9.9 or 8 hp kicker to my rig. First, if I just a steering link, how does that work when lowering the engine into the water. Meaning, my 90 is power tilt, would I have to lower the 9.9 one notch, then lower the 90 a little, etc till they're both in the water. There's got to be an obvious answer to this that i'm not considering.
    Also, right now I have a side-mounted throttle control. Does Yamaha make a binnacle that allows me to have throttle/shift controls for both engines on the same binnacle?
    And if they do have a double binnacle, what's involved in bringing my existing control cables from the side-mount to a binnacle. Is it just a matter of removing them from the side-mount and affixing them to the binnacle?
    Thanks - glad I found this forum.
    2005 Xpress HD18CC
    2005 Yamaha 90
    Rooting for the Yankees is like Rooting for the House in Blackjack
    There are aftermarker(Yamaha doesn't offer them) steering link arms for auxilery motors that has a quick disconnect on them to remove when not in use.
    You could use a dual binnacle control box but would probably have install new control cables, would need to install key switch and harness for eack engine.
