I recently purchased a 2005 yamaha 90 hp 2 stroke. The digital tach works, but the trim indicator doesn't. The trim indicator shows down position. The trim sender is a 2 wire with 8 ohms down and 180 ohms up. The tach/oil sender 4 prong connector is not connected at the motor. The trim sender plugs into the 2 wire plug and then into the wiring harness. I would appreciate any help with this.
2005 Yamaha 90 hp 2 Stroke trim indicator
