Hello together,
I bought a used 250 hp (Serial: 61A X 1000728).
Unfortunate my boat workshop messed up this engine.
First trying it – I had lots of power – but during idle the engine always stopped (partially with backfire).
Then the mechanics mess the carbs in order to find a better adjustments – with no success. I gave up with this workshop and try to find a solution myself. I realized that two sparks are washed so I replaced all six sparks. I saw also that these fabulous engineers did not fix the blind plug proper so a screw of the carburetor jets got lost. I fixed all that.
As result the engine works now in idle – no more backfire. But it takes very difficult throttle and the maximum power is much lower.
So I guess I need to adjust all carbs – right?
But how I do that?
Is there a basic setting for the carb jets – like close and then open 2,5 times – something like that?
I try to find a repair manual for that engine – but I could not find my type of engine.
Help is really very much appreciated.
Thank you
But how I do that?
Thank you
