8HP-(2008) 2 Stroke-Pee Hole ?
I last used engine last spring. Started engine to perform winter storage. No water from pee hole.
Used small drill rod to clean out tube ( really didn’t find any blockage). I increased water flow to muff and now water flows OK while engine is running. (Maybe the water flow to the muff was not high enough initially- or the thermo wasn’t passing water-or some other blockage ) ???
Question: The distance that a cleaning rod can go in is only about an inch or inch and ¾.
So I’m assuming there is a flat plate above the tube and the water comes in at an angle.
What can be used to keep this passage way clear? “Search “ didn’t reveal any answers.
Seems like a complicated design for simple water flow indication.
Thanks for any comments.
