Hello!
My tilt trim does not have any apparent external leaks. If I raise the motor, it will slowly leak down.
When I raise the motor, it sounds as if there is air in the system.
I have gone through the purge process of raising and lowering the motor all the way up and down while adding fluid in the full up position.
What could be leaking internally that would cause this problem?
Also, the 3 allan head screws holding the motor and valve assembly on are stuck. There doesn't seem to be any corrosion, but there must be or a lot of loctite was used.
Thank you for your knowledge!
Aaron
Aaron
