Hi Folks! I have a 1989 Yamaha 30ELF which I am replacing the prop, prop nut, all spacers and cotter key on. Can anyone remind me what the install order is when you start with a completely bare prop shaft?....I believe the order from most inside part of shaft is ......1.) spacer...2.)prop....3.locking spacer....4.thin washer....5. castle nut....6. cotter key....but I can't remember which direction the 1.) spacer goes?....just want to confirm the order of install...thanks!
1989 ELF30 prop install instructions needed
