50hp Yamaha Pro 50LF not running onall 3 cyl
  • 50hp Yamaha Pro 50LF not running onall 3 cyl
    I have a Yamaha Pro 50 LF that runs rough ,
    Checking for spark at the plug wires shows that there is spark there but not very stong .
    Pulling off a plug wire on #1 cyl shows no difference in its running , 2&3 show some difference .
    When I moved the coils around with #1 to #3 , number 3 was dead .
    When I pull all three of the plug wires off individually I can hear a snapping on all of the wires but very weak even the coil that does not fire the plug, etc. #1 coil that I moved to #3 .
    Do you think that this is a coil problem or is it deeper in the electrical system ?
    Thanks for any help
    Bruceter
    bruceter@kw.igs.net
    Test the inputs and out puts of the CDI and compare to the specs in the manual
