I have a 1988 yamaha 90 2-cycle exhaust errosion problem on the channel walls allowing water into the cylinders. Are the aluminum walls fillable with the motor mounted on the boat? J-B Weld, Steel Putty or HST-2000 an option? Thanks Mark
yamaha 90 block repair
Never tried it not sure if would be able to get it to stick on stay in place.
Thanks no it is still intact. Today I used steel putty to fill the holes and cracks, then coated with J-B Weld, will recoat tomorrow. Will put her back together Sunday and see what happens!
Mark
I am a Diesel Tech for a local dealer in North Carolina. I don’t recommend using J.B. Weld to repair a damaged block. There I got what I am supposed to say out.
Now, for the good stuff. I had a block that was pitted where the lower part of the liner meets the block. I used the famous J.B. Weld to repair the pits. I layered the product in with thin layers. I took roughly 3 layers of product. I then sanded the affected area until it was smooth and you could see the dark spots where the product was installed. I waited 24 hours before sanding. I had the pleasure of rebuilding the same engine after 250,000 miles after the repair was made. I was astonished to see that the repair held up after so many miles. I have since made similar repairs to different engines when the owners did not want to replace the block.
As long as the cracks are not very wide or very long I think that your repair will have the same success.
Good Luck!!!
Well put her back together and started right up and idled fine. Took her out for a ocean test ran great, will try again for a much longer run this weekend but so far very incouraging.
Mark
Well I got 10 months from my repair, she was sounding a little off so I removed the exhaust cover to find the epoxy started to de laminate. I repreated the same procedure and hope to get 6 to 8 months more out of it.
ÂÂÂÂÂÂ
