How to repair in yamaha f100 tlra (2002). Entry of water in gear? The problem is that the change oil proven that he went milky.WOULD LIKE TO KNOW HOW TO REPAIR THIS DAMAGE
How to repair in yamaha f100. Entry of water in gear?
Are you talking about the gearcase, the part the prop is attached? If so pull the prop and look for fishing line in the seal. If there is none the you will have to pressure test the case and find the leak. The best solution is to reseal the gearcase.
Now if it is the crankcase engine oil then you may need to replace the oil pump. There is a revised oil pump assembly to address the lower seal issue.
yamaha f100
Prolem GOT THE GEAR IN THE TAIL ON THE CARTER NO.
THANKS FOR THE RESPUESTA.HE TAKEN THE WATER BOAT OIL ME BECAUSE HE HAS GONE BLANQUECINO.LE OIL UNTIL SEVERAL TIMES REMOVED PROPELLER out BLANCO.HE SCREWDRIVER WITH HE REMOVED THE OUTER SEAL, YOU JUST ASK FOR A BOAT NET AND WHEN YOU RECEIVE COLOCO.UN affectionate greeting.
Last edited by pardo600; 10-18-2010, 02:35 PM.YAMAHA F100 LFAR THAT TAKES TURN ADJUSTING SCREW FACTORY MIX?[COLOR="Sienna"][/COLOR]
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
