70 hp 70TLRZ all new parts in enricher all carbs clean .how is this thing supposed to work no fuel at all while cranking. Engine will start if I choke it with hand over carb.
carb enricher
Make sure the red lever on enrichinger is in closed or normal position, look in owners manual for correct position of lever, www.yamaha-motor.com has the manuals you can view.
Trim motor down all the way, pump up fuel primer bulb, start engine with throttle lever in idle position. Engine should start.
