starter on 25 HP
  • starter on 25 HP
    My starter will not stop. I have checked the switch and found it to be working with an ohmeter. I disconnected the switch and when I connect the battery the starter goes right away. Help?
    Possible starter solenoid bad.
      Same problem
      Had the same problem on a 2001 25hp 4 stroke Yiamie. I replaced the solenoid, all good. It happened at around 400 hours.
        Thanks. Is it an easy job?
