If I take the mounting screws out of the pumps to where the fuel pumps are off the motor but the fuel lines are still hooked up and i pump the primer bulb should gas leak out of the pumps
low pressure fuel pumps
yep you right just remove the 2 that hold the fuel pump on to the engine .....and no there should not be any fuel leaking out of the pulse port
ÂÂÂÂÂÂÂÂÂ
