i just got this motor---70hp 2 stroke 1986
it starts and idles fine but when i put it in gear its as if it is only running on 2 cylinders and is hard to keep running
after throttling, it almost dies at low rpm until it hits a lower point of load then takes off like crazy. it runs good after picking up
what can this be?----i've adjusted all the timing screws and messed with the throttle screws and still does the same thing.
i disconnected the vro oil injection and just mix gas into the tank 50-1
could the oil level sensor be causing this?
