I have a 1996 yamaha 150hp V6-2596cm3
Alarm first started when cruising across the lake at full speed. As soon as alarm went off it went into rpm protection mode. After killing it and letting it cool off I was able to restart with no alarm. If I went slow I could go a ways, but the more rpm's the faster the heat and faster the alarm. Now i can just start it and let it idle for about 3 minutes and alarm goes off. The impeller pump has been changed since and tonight I tested the thermostats which seem to be working just fine. This boat does not have an oil pump as it's self mixing. Where do I go from here to figure out the reason for the alarm????? Thanks in advance!!!!!!!!!
Ron
Ron
