Water Leak Around Bolt
  • Water Leak Around Bolt
    After a good day of fishing I did an inspection of my Yamaha 9.9hp I found water leaking around a bolt on the rear of the motor while running (this was done with it out of the water with clean water). After shuting it down I loosened the bolt and oil started coming out so I retightened the bolt and started looking for what the bolt was --I figured it maybe the oil drain but really don't know. What is this bolt and is there a big problem here? Are there parts I need to repair this if so?
    This bolt is just below the small exhaust/vent on back of motor.
    Oldbait needs some help here ----Thanks
    Info on the motor is below.
    1995 Yamaha 9.9hp
    T9.9EXHT
    The oil drain plug is number 15 in this diagram Yamaha Outboard Parts 1995 T9.9EXHT OIL PAN Diagram
