But it will start easily if the little red (Emergency Fuel Enrichment" lever is used and will start again when lever is returned to normal. I've changed the "Prime Starter Asm". Apparently there is no "choke" on this model. For years I've been holding in the key "choke" when starting thinking that was the way to choke it. Also there is a small connector that was disconnected. It sounds the alarm when connected. There are olny 2-3 wires in it. I don't think that's related to the starting problem since it's been starting, but maybe one of you experts know more. I plan to replace the fuel filter and check the fuel pump, but would it start at all if there was a problem with them? Does that leave only the carb as a possibility? Thanks for any help.
franc
franc
