I, and both of my brothers own 30 HP Yamaha outboards. ALL of these motors have oil leaking out of the oil injection storage tank level moniter rubber cap. How can we fix this and stop wasting Yamalube?
Oil Tank Leak
We run these motors on level trim. If you fill the oil reservoir to the filled line, the oil will not stop leaking until the level drops below the sensor cap. This was a badly designed setup. Seals incorporated in the sensor unit itself do not provide a tight seal to prevent oil loss. I have used ty-raps to no avail. Filling the tank to just below the sensor cap is the only way I have found to not lose oil, but the low oil sensor kicks in much sooner than running with a full oil tank. I will try an O-ring on the sensor itself to see how it works. Thanks for your responses.
I just want to know if anyone else has attempted to FIX the problem, not to just avoid the problem.
oil sensor replacment
If I replace the oil sensor, what gurantees the replacement won't leak also? I hate to spend over $100 to have another leaky sensor!
ÂÂÂÂÂÂÂÂ
