Looking for help with an oil pumping problem with my Yamaha 200 HPDI on a 22' Grady. I don't have an hour guage but probably 400 hours on the engine. In the past 7 years, I've had great luck with this engine (only one VST filter issue)
The electric motor built into the oil tank does not now pump oil up to the smaller tank on the engine. So far, I've removed the larger tank (very clean in the bottom) and checked the pump. The pump worked fine directly connected to the 12 volt battery in my car in the garage. Pumped oil out of the tank. I took it to the boat and tested in onboard before installing the tank in the bilge and it worked fine again, I used the emergency toggle switch to operate it.
I reinstalled the tank, connected the harness wires, etc. and set off. The pump didn't resupply the oil and I had to add oil manually to the top tank. The toggle switch also didn't activate the pump. The low oil alarm works fine.
I got home and tested:
- the pump again with my car battery - OK
- the 3-position oil sensor inside the small oil tank using a multimeter, as per the manual, and it checks out fine.
- the emergency toggle switch tests OK too
- each of the 4 wires in the harness that runs from the top of the large oil tank to the engine test OK
- plastic couplings look OK too. I sprayed with WD-40.
No luck in getting the pump to do its job and now I'm stumped. Any ideas?
