VMax SHO tiller??
  • VMax SHO tiller??
    This is kind of a doozy of a first post but figured I'd ask. I am having a new jet boat built for running the rivers up here in Northwest washington. I'm looking to put a 225 VMax SHO on the back. The 2 questions I have is I need to put a tiller handle on it and a jet pump.
    First, what tiller handle do I need? I believe the new multi-function tiller PN# 6X4-42101-00-00 should do it but not sure about which fitting kit I need?
    Second, as long as the crankshaft and mid housing bolt pattern from the new vmax sho are the same as the ones off the F200, F225, F250 I should be able to use an AQ jet unit from Outboard Jets. Can anyone verify or know if the parts and patterns are the same.
    thanks
    sean
    Yamaha only list tiller handle kits for up to 115hp motors and jet drives for F40-F150 motors.
