Leaking #3 cyl-90hp-1997 Yamaha
  • Leaking #3 cyl-90hp-1997 Yamaha
    Help- water leak in #3 cyl on a 97 Yamaha 90 hp.
    I screwed up several times but want to make sure I am right this time.
    The disaster
    1 Plug fouling out with water-cleaned several times, still water found. 2 Pulled head and cleaned all surfaces.
    3 Installed new gasket and torqued to 800 in. lbs. Looked carefully before starting and found I had turned the gasket the wrong way. Pulled and turned gasket around and retorqued the gasket, did not replace.
    4 Started engine, pulled plug after running for ten minutes, still leaking.
    5 Pulled head and cleaned up surfaces.
    6 Installed new gasket and retorqued to 800 in. lbs
    7 Pulled plug after running for 5 minutes, still leaking. Screamed and went inside the house. Went on the Internet to read, found I had wrong torque.
    8 Found the proper torque needed to be 11lbs and a final of 22 lbs.
    9 Retorqued the head to the new numbers, ran and it leaked. Engine had ran only 5 minutes with 800 lbs torque before I retorqued to 22 lbs. I assume running and leaking ruined the head gasket.
    10 Pulled and cleaned up the surfaces. Have new parts. If I install a new gasket, aligned correctly with the correct T. values should this stop the leaking.
    wes
    Check for holes in head, corrosion will damage head on water jacket side and corrode a hole into combustion chamber, need to check exhaust plate as well to look for holes.
      Head and area
      The head and the surfaces look fine. No cracks wear or tear. Can I be getting water in through the exhaust port in the cylinder?
        Yes remove the exhaust cover and check inner plate closely.
