Hi
I have a Yamaha 140ALTO v4 2 stroke 1987
My trim indication isn’t working
On the trim sender there is 5vdc on Orange wire and ground on black wire, but pink wire is constant 2,5vdc. (also a grey wire but NC)
So my conclusion is the trim sender is defect, agree?
Will the existing old Tachometer with oil level and trim work with a new type “6G5-83672-00-00 Trim sender” ?
Or do I need to buy “6y5-83500-t2” to make the new trim sender work? But will the Tachometer and oil level work with the old motor harness?
Thanks in advance
Thanks in advance
