Help with ignition switch
  • Help with ignition switch
    I have a 1996 Yamaha 130 on a 18 seacraft.
    The Ignition switch is casuing problems: the red wire when wiggled cuts of power to the switch. Also teh puch choke stpped working.
    This is a sealed switch so I need a new one.
    Anyobne know which one to order, ther doens not seem to be a part number on it.
    Also anypn enow the what each wire is for?
    1 red
    2 yellow
    2 black
    1 blue
    1 white
    1 brown
    Thanks for any advice. I am trying to fix it up so I can sell it.
    If it's dash mounted switch panel then use 704-82570-08-00 switch.
    red= 12v battery power
    yellow=key on power
    black= ground
    white= ignition stop circuit
    brown= starter circuit
    blue = choke
