9.9 throttle control loose
  • 9.9 throttle control loose
    My 2000 yamaha has the twist grip throttle on the control arm. Yesterday the entire piece that turns was loose and it would actually pull completely off the arm. I can look in the end and see the spiral groove that moves the throttle cable. On the shaft that remains I can see the things that slide in and out that controls the speed. I know the piece must rotate but I don't see anything that holds the grip onto the shaft. What holds this on?
    It's held with a screw, number 15 in this diagram Yamaha Outboard Parts 2000 9.9MLHY STEERING Diagram
      I think this diagram matches my outboard.
      It is a little different than the one you posted.
      Yamaha Outboard Parts 2000 F9.9MLHY STEERING F99MH Diagram
