200 HPDI stalling
  • 200 HPDI stalling
    Still having trouble w/ my HPDI. At idle, engine will run approx. 5 minutes and stall. If you prime bulb, engine starts right up and will run another 4 or 5 minutes, sputter then stall. Above 1200 - 1400rpm engine runs great, but above 5000rpm engine will stall out.
    I would like to hook up an external 6 gallon tank to see if I have contaminated fuel, a blockage in the fuel pick-up or an air leak. Do I connect directly to the engine, or splice into the line as close as possible? Do I need any special fittings, connectors or adaptors? Any help or guidance would be greatly appreciated. Thanks!
    200 HPDI Stalling - additional info
    Forgot to mention in-line filter has been changed numerous times, fuel cup has been drained frequently and O-ring replaced and VST tank has been drained with no sediment.
