88 excell 225
  • 88 excell 225
    compression test showed 125 psi for the high and 105 for the low how bad is that all the # were 125 105
    115 115
    110 105
    motor runs and sounds nice what do you think
      That's fine. Might have some sticking rings on the low cylinders. I would run the motor on a strong mix of Seafoam/gas and spray Deep Creep in the carbs and I bet those lower numbers will come up.
      Anything 80 psi or less is usually trouble.
        i did a better test took all plugs out and tested 125 1 +2 cyl 125 3+4 115 5+6 the book says 5+6 are the lowest
        fell better now
