I have a new 2010 150. Water separators are rated by gph. How many gph does a 150 use? What size connections do I need, I see 2 size options. Also I would like the clear bowl on the bottom.
Which fuel filter separator?
Generally your motor will burn about 12 to 15 gallons per hour at wide open throttle, but go to: Yamaha Outboard Performance Bulletins for more detailed information regarding MPG, GPH, MPH for your boat/motor combination. The finer the filter, the more quickly the flow rate(GPH)will be effected by water/dirt/debris, so your unit needs to be oversized to allow for this and not create a restriction/lean fuel condition. Good Luck!
I use the 2-micron Racor. The high pressure pump screen and fuel injectors use a 2-micron so it only makes sense.1999 Grady Sailfish SX225 OX66
ÂÂÂÂÂÂÂÂ
