air in fuel filter
  • air in fuel filter
    I have a 2001 2 stroke Yamaha that has a see through filter attached to the port side of the engine. While the engine is running the gas level drops down about a third of the way resulting in a loss of rpm at high speeds. When you pump the ball it fills completely but then slowly decreases. I have replaced the filter and seals in this filter, replaced the in line water seperator filter and replaced the primer bulb. I have also inspected the hose from the tank to the engine and can't detect any leaks.
    Any ideas?
    Sounds like the fuel pump is bad.
