2002 225hp 4stroke oil alarm
  • 2002 225hp 4stroke oil alarm
    New to me boat and engine, second time out.
    After about 15 minutes of running at 10-20 mph I slowed down to dock . I raised the drive slightly because of 2' water. After 40 seconds of idle speed the oil alarm sounded. I shut down the engine and removed the cowl. The oil level was fine. The engine was running fine prior to the alarm. This happen 3 times under similar circumstances.
    Oil and filter are new this year, oil is very clean. Engine run fine otherwise.
    Any help is appreciated!
    Rich
    have checked oil pressure with gauge might be oil pressure sender they are not cheap and are very sensitive to the proper running to your engine
      number 63 check that this the correct model
      Yamaha Outboard Parts 2002 F225TURA CYLINDER CRANKCASE 1 Diagram
