My neighbor has a Yamaha f90txrc outboard that he is replacing the prop on and we need to know the torque spec for the prop nut. We don't have manual and any help would be great.
Tighten it good and darn snug, then just a bit more until the crown nut slots and the hole in the prop shaft line up for the cotter pin. Install a new cotter pin and bend pin ends over tightly to prevent any movement, and you're set to go! Good Luck!
