I have a 01 yamaha 115 2 stroke that was not making full power. I checked the spark, and cylinders 2 & 4 were not fireing. Put in new plugs and problem persisted. Switched the port, and STBD ignition coils around and the problem stayed with cylinders 2 & 4. I think it is in the CDI. I am looking for a way to test the CDI (don't have a good one to switch it out with) to make sure it's the problem before i spend $500. Could it be the stator coils? Any help would be great. Thanks.
03 115 CDI issue?
Could be charge coils, pulsor coils or CDI unit, probably pulsor coil.
Can run voltage output test with peak reading voltmeter and resistance test.
cdi
I have same issue with a 96 200 yamaha . If you find a repair for your motor please post a reply that i might try the same thing on my motor. My motor is missing on cylinders 1,3 & 5 . Thanks and good !
ÂÂÂÂÂ
