I have a 1999 BayMaster 22' Guide Series that came with a 1997 150 Yamaha Vmax and a TRP lower unit. The lower unit blew out reverse and upon a quote from the dealer..."we're at $2800.00 and counting, what do you want to do?", I am lost. Should I repair, buy new or replace with a single prop lower unit? I have been looking around and found a new replacement for $2800.00 but does not include wanter pump or props. So i have the props from the lower unit along with the water pump so I guess it is just the labor to attach. The other side...if I go with a single prop, I will have to purchase the prop and water pump. That could cost the same as the TRP. So To BE TRP or Not To Be TRP is the question.
TRP To Be or Not to Be
