2005 round tach/oil/trim gauge??????
  • 2005 round tach/oil/trim gauge??????
    My Starboard gauge will not go down past 2 bars. It was working fine and this past weekend it stops at 2 bars when I try to trim down. It shows all the bars going up and the trim works just fine. I have twin 150 motors
    I tired to wash and lubricate it when I got home. I lifted the trim send up and down and works just fine.
    Is their a way to calibrate the gauge or do I need to adjust the trim sender b/c it might have shifted?
    Some models have a plastic cam on tilt tube that activates trim sender, check to see if broken. The trim sender can be adjusted slightly by loosing the mounting screws and resetting.
      much appreciation for this post...I found out my problem by reading this
