Guys,
I have a couple of questions regarding trim & tilt on a 2000 OX66 VMax 150HP.
First off, am I reading the manual right, in that one shouldn't transition from tilt to trim while the motor is under power? By under power I mean idle/*****ing speed. I'm asking because -
Here's the second question. I just purchased this motor. It has sat idle most of this summer. When I transition from tilt (up, beyond trim range) down to trim I'm getting a "creaking" sound. The trim motor sounds fine. But the creaking sound is disconcerting. What would you guess is going on? FYI it seems to dissapate after I've used it for a while.
Could it be a t&t fluid issue? Does this sound like something I should have a dealer/service center look at?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
