New fuel pump is a water cooled fuel pump. need to remove water tell-tale hose from engine and hose nipple in lower cowling, install hose supplied with fuel pump to fittng on engine and to fuel pump, install other hose from fuel pump to nipple on lower cowling. F9.9WaterColledFuelpump.bmp
