Engine missing and dying at low speeds
  • Engine missing and dying at low speeds
    I have a 50 HP 2 stroke Yamaha outboard. It has started missing and dying at low speeds and idol. I noticed the motor smoking more than usual and at one point an alarm went off. Water is going through motor, and didn't seem to need oil. Any ideas?
    Thanks.
    Ed
    Need to run a compression test, check for spark at plugs, replace spark plugs and fuel filters, may need carbs cleaned. May need new water pump if alarm is going off.
