03 vx250. Started off the morning great made a few stops and then we were running to the next hole, motor shuts down. We checked all connections and did what we could on the water. Motor cranks but will not fire. Towed in 14miles. Put a meter on the high pressure fuel pump reading is 10.86. But you dont hear the motor when the key is on. Dropped the vst tank, full of fuel, filter changed 2 months/10 hours ago. My question is how do you know for certain if the pump is shot? After dropping the vst I reconnected the pump and held in hand with the key on and nothing. Switched polarity still nothing. Before I drop $800 want to make sure the pump is bad.
yam ox66 hp fuel pump
Pic
Had the dealership double check the pump to make sure and it's dead!
Here's a picture of the pump off the website I ordered the replacement.Attached Files
ÂÂÂÂÂÂÂÂ
