The gauge is operating partially, its showing fuel gauge, clock,voltmeter and warning indicator but is not showing speed or trip meter. Can this be repaired or do I need a new one. I cleared out the hole in the lower unit of outboard but it didn't help. Any suggestions?
Yamaha multigauge speedometer # 6Y5-83570-S5-00
Probably still blockage in pickup hole or pinched speedo hose between engine and gauge. Try applying about 20 psi air to hose at speedo to see if air comes out hole in gearcase.
If unable to clean passage in gearcase then may have to install a transom mounted Pitot Pickup on boat and connect speedo hose to it.
I just noticed my speedo is not working. I haven't cleaned the pick up hole yet, since I just learned about. I will clean it tonight.
The water pump was replaced last month. Is it possible the hose from the pick up hole was disconnected and never reconnected during the water pump replacement?
Thanks in advance
ÂÂÂÂ
