I have a couple of problems with my 1995 4-stroke 9.9 hp Yamaha outboard, ser. # F9 9MSHT 6G9 S 009147 Y
1. It is hard to start. I have best results by slowly pulling the starter rope out pretty far, then giving it a hard, sudden ****, and most of the time it will start but frequently will then die quickly, before it really starts to run.
2. At times, after it starts it seems to be "running on one cylinder" (half speed) for a few seconds to a minute or two, and then it will kick in to full power and run fine, at maximum speed, until I throttle down to low speed and/or put it in neutral, when it will die completely.
I have new plugs and fresh clean gasoline.
Any suggestions for easier and smoother starting, and for preventing it from dying when I throttle down to lowest speed and/or put it in neutral?
