92 200hp on a mooring in cold salt water with no marinas nearby has its fin zinc deteriorating fast. Would this be a bad ground? How do you trace problem? Thanks
anode deterioration
Originally posted by conniption View Post92 200hp on a mooring in cold salt water with no marinas nearby has its fin zinc deteriorating fast. Would this be a bad ground? How do you trace problem? Thanks
do you leave the leg in the water ? put a couple extras on the hull of your boat on the back so they are in the water when boat is at rest.
but as said that's what is supposed to happen just replace it
anode issue
Originally posted by mitch View Postdo you leave the leg in the water ? put a couple extras on the hull of your boat on the back so they are in the water when boat is at rest.
No shore power,no tabs, no clue...
You may have some stray leakage currents on your boat. Probably need to do some research on it. I think have read some way of testing but can not remember where or what it said.
Maybe look for wiring laying in water in bilge, automatic bilge pump would be a thought. Any noble metal contacting the water could cause it also, dissimilar metals form a battery type effect and cause current flow.the anode is designed to go first and keep the motor from corroding.
ÂÂÂÂÂÂ
