Last time I had the boat out I had some problems with what I think was overheating. Did fine until I headed back to the launch. Hadn't really used the motor much, just running from different spots on the river but there was a lot of seaweed in the water. The motor worked fine and then reduced down to almost an idle speed and the alarm sounded. Shut the motor down but when I started it again it seemed to be working properly with no alarm after that but it didn't seem to have it's usual power. Still spitting water, but I didn't think to check that until I made it back to the launch. Any ideas from you guys about this, clogged cooling system possibly?
Overheat alarm?
