F115TXRZ not charging
  • F115TXRZ not charging
    My 2001 F115TXRZ is not charging. I have cleaned all cable connections and charged the battery. With motor not running, I read 12.6 volts on digital voltmeter. When starting, it obviously drops and when running, it comes back near 12.6 volts. When I increase motor speed, there is no change in voltage. I have two motors on seperate batteries and when I check voltage on the other motor, it reads close to 14 volts when motor is running. I have checked the 30 amp fuse and it checks good. How can I determine if the problem is the rectifier or the coil?
    Probably bad regulator, inspect it for burnt wires or burn marks on back of regulator.
