New to Yamaha outboards. I see a screwplug on bottom lower unit just under cav fin labeled "WASH" . Do I have a salt model? 6MSHR code 6H6 S . This plug is 1-2" above the water inlet. What is the procedure? It's not peeing well anyway and making order for impeller etc.... I see a " Flush Kit For 4 6 8 20 40" part #ABB-MOTOR-FL-SH It looks like a garden hose adapter for this "Wash" hole and also a set of muffs for $11. Will this fit my motor? Just hook upgarden hose and let her rip?
"WASH PLUG" on 6MSHR
Same Question with Wash Plug
Originally posted by overthehill View PostNew to Yamaha outboards. I see a screwplug on bottom lower unit just under cav fin labeled "WASH" . Do I have a salt model? 6MSHR code 6H6 S . This plug is 1-2" above the water inlet. What is the procedure? It's not peeing well anyway and making order for impeller etc.... I see a " Flush Kit For 4 6 8 20 40" part #ABB-MOTOR-FL-SH It looks like a garden hose adapter for this "Wash" hole and also a set of muffs for $11. Will this fit my motor? Just hook upgarden hose and let her rip?
Need to know if this Wash hole should be plugged when not using it
as a wash .
Thanks if you can help
forger
ÂÂÂÂÂÂÂ
