50 hp 4 stroke troubles
  • 50 hp 4 stroke troubles
    Having trouble with a 2000 50 hp 4 stroke. Starts and fast idles great. When you place it under a load it acts starved for gas. Can't get the boat on plane. I have cleaned the carbs, checked the plug wires, changed the plugs, checked the fuel filter, and am using new gas. Any suggestions?
    That would be hard to say it could fire, fuel or compression.
      hert,
      Is it missing when you try to get on plane, or running smooth but just no power?
      I would suspect fuel pump or timing on the ignition - might want to get yourself a Yamaha shop manual and run some tests.
      Good luck,
      Ken K
