yamaha multifunction tach
  • yamaha multifunction tach
    Hi all
    I just got a 2003 75 horse Yamaha. Could you please tell me how to use the multifunction tach on it!
    The digital numbers in middle is the engine RPM's, the overheat and low oil warning lights are at bottom of tach and the eng. trim indicator is on the right side of guage. If it's the newer tach with hour meter it will have a mode and set button on bottom of guage. The mode button will toggle between hour meter and trip meter. The trip meter logs how much time the engine runs on a trip. the reset button zero's out trip meter.
      thank you very much 43 that helped a lot. time to go fishing!
