115trld water pressure drop
  • 115trld water pressure drop
    Have a 2005 Yamaha 115trld w/carbs. I am certain water pump is going out. Tattle tale water pressure lower than normal & gauge shows about 12-15 psi drop from normal. Before I change out water pump, where does the tube coming from the (Yamaha Water Pressure Gauge) connect to the engine? Just trying to cover bases before repairs. No overheating or alarms.
    could also be your pressure relief valve stuck open
