Symptoms
- Spark Yes
- Compression Yes, All 3 cylinders within 3 psi of 105, but engine seems to turn over too rapidly
- Gas No
Problem
Gas enters through jet upstream of b- valve in carburetor during normal operation of venturi at operational speeds. Therefore, since vacuum within carb with b-valve shut excludes the jet, the choke must put gas into engine other than thru jet on start. Attached to center carb (see pic) is a solenoid. After removal and testing, it energized but did not function to retract the plunger. I am assuming that this solenoid allows for gas to enter carb somewhere on vacuum side of b-valve during startup.
Question
Obviously, my knowledge is limited. Please comment on anything that may be helpful.
- Spark Yes
- Gas No
Problem
Question
