I have change to new thermostart switch.I have tried to put in in boiling water to see if it's work but the engine still running.Ive tried to heat it with lighter but still running.What is the problem.My engine is yamaha 2 stroke 85hp
Thermostart switch
From what i know that thermostart should limit the rpm or even shut the engine when the engine is overheated.When i start the engine and put the thermostart in boiling water,the engine still running.then i tried to heat the thermostart with lighter but still nothing happen.what is the prob
TQ for the info,I've try to ground the pink wire and the buzzer is still functioning.One more question,my engine is shaking at idle,not like normal but steady at higher rpm.I have clean tne carb,cx all the fuel inlet at fuel pump but still shaking.Any ideas?
Edit/Delete Message
Â
