Broken Axle
  • Broken Axle
    The axle bolt that my 5 cmhl 5 hp two stroke 1998 engine has sheared on one side. It is the bolt on which the engine swivels up and down.Has anyone else had this problem? What is the part called? and can it be replaced easily?
    Peter
    I believe you are talking about the tilt tube, but not sure on that small of a motor what it is called
