I am changing all the old and damage connectors under the console of a 18.8 boat. The remote control (single 704) only has 3 wires coming from it light blue, light green and red. It's different from the schematic founded from Yamaha. It does not has the brown wire (neutral switch wires) I matched all the cables but the starter does not run. I will appreciate any advice. Thanks
1986 200hp remote control wiring problem
The brown wires are the starter circuit wires and should be there unless someone has removed neutral switch.
the brown is connected to the brown on the motor harness. There is not kill switched, I connect the white from the starting switch to the white at the harness. My doubt is on the red and the yellow. Both should be connected the the fuse panel?
light blue, light green and red sound like these are the T&T wires.
Yellow is key on power and red is positive to switch
ÂÂÂÂÂÂÂ
