I have the 200 hpdi with the down trim on the throttle inoperative, the up functions normally. The trim still functions with the local switch on the motor. The throttle assembly mounts to the side of the gunnel. I would like to remove the switch but can't easily get to the back side of the throttle assembly. Can the switch be removed without removing the entire assembly? I would assume?? that since the up down on the local switch works all the relays,and hydraulics are ok.
Thanks in advance. Jim
